help! coolant leak
Old Apr 6, 2005 | 01:30 PM
rhubarb's Avatar
rhubarb
help! coolant leak
i just bought a 94 ranger 2.3...well it wasnt warming up quite right so i decided to change the thermostat, and the hoses...well the lower hose i decided to leave alone....and i changed the thermostat and upper hose, as well as a heater hose....well now the thing is leaking antifreeze like crazy....its not coming from the thermostat housing or the upper hose....i looked under neath and it was coming from above the crankshaft pulley....well i just dont understand ...it did not leak a drop before i took it in the garage.....well any help would be appreciated...
Old Apr 6, 2005 | 02:01 PM
G2IC_Wraith's Avatar
G2IC_Wraith
You need to try to pin point the source as best you can. The only connections around there are the 2 heater hoses and the upper rad hose. Are you sure you have the t-stat in correctly? Also is the water comming out of the weep hole from the water pump? Pumps can leak when they start to go bad.
FYI - you may need to watch the titles of the posts. Titles that are too vague won't attract the proper attention.
Old Apr 6, 2005 | 02:10 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
He's still got time to edit it; 60 minutes after the thread was first made .
