F250 Overdrive
F250 Overdrive
The E4OD is not a bad tranny at all.AS LONG AS ALL OF THE UPGRADES AND TECH BULLETINS ARE PERFORMED. Well with that said(I may just be trying to convince myself that the last $2800 go-around was the end all to beat all). You didnt mention if you had a 4x or 2x and which tranny you currently have. If you have the C-6 tranny, it would be ashame to get rid of it.The C-6 is an awsome reliable automatic.If you have a 2x I would consider,installing an overdrive unit at the drive shaft.Its really a trick set up it gives you an overdrive,in every gear,(activated by a button on the gear shifter). Gear Vendors and US Gear both make units in OD or underdrive.I dont know anyone with a GearVendors unit but a freind of mine has had a US Gear unit on his rig for years and loves it.
Jeff
Jeff
F250 Overdrive
I've heard the same thing about the E40D. Then again, I'm sure they could be built to work reliably. I too, have the 460. I've got a C6 and wouldn't think of getting rid of the best auto tranny Ford every built. I've considered the Gear Venders unit, but can't swing it right now. Mine's a 4wd, and it'll work fine 2wd. The Gear Venders unit 'locks out' in 4wd. It's only turning the rear shaft. Who needs OD in 4wd, anyway. Anyway.. I've done a lot of research and I agree that an aftermarket OD unit would be the only way to got.
DM
DM
F250 Overdrive
[font size="1" color="#FF0000"]LAST EDITED ON 13-Jan-01 AT 00:38 AM (EST)[/font][p]I presently have a Geavenders Overdrive on my 1976 F250 powered by a 353T Detroit engine, which has as much torque as a 460. It presently has 200000 miles on it with out any major problems. If you have any questions about it feel free to reply and I will try to answer your questions.
F250 Overdrive
>as a 460. It
>to reply and I will
Now here's a guy I can relate to. I often wondered if anyone had ever put a Detroit Diesel in a pickup and was considering taking up the project myself at some future point.
Way to go Redbear!!!
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
>as a 460. It
>to reply and I will
DannyP
