Gas Tank
Old Apr 4, 2005 | 11:36 AM
Alviejp's Avatar
Alviejp
Gas Tank
I have a 68 ford F100 that i am working on relocating to under the bed. I was wondering, what tank(s) could I find to fit under the bed for that truck?
Old Apr 4, 2005 | 12:13 PM
qman's Avatar
qman
Do a search. That's been discussed here many times. I think some guys go with a mustang tank and it fits perfectly under the bed between the frame rails.
Old Apr 4, 2005 | 05:46 PM
bcam69's Avatar
bcam69
alvie - I have done alot of searching on this topic on this site, and it seems that every time someone brings it up they say do a search. From what i have researched and read, most people talk about the Mustang tank. But I don't think I have read a thread where someon has actually done it on a 67-72 truck. most of them refer to the tech article a member did on a 54 truck. I sure would like to hear from someone who has done it on a 67-72 truck. I'm not saying I have read every article on this site about the conversion, but I have spent a couple of hours for sure.
Old Apr 4, 2005 | 07:19 PM
4Cammer72's Avatar
4Cammer72
here's a place to start at least https://www.ford-trucks.com/article/...1953_F100.html
Old Apr 5, 2005 | 12:10 PM
qman's Avatar
qman
That looks about right. Too bad the search isn't easy. But I know I've read a number of threads in here where guys have put a Mustang tank into their 67-72 trucks.
Old Apr 5, 2005 | 12:41 PM
Red2003XLT's Avatar
Red2003XLT
Ford offered an underbed gas tank as an option, look around your boneyards. You may find one.
Old Apr 5, 2005 | 11:16 PM
WillyB's Avatar
WillyB
My 72 has a 20 gal aux tank under the left side of the bed, from the factory. It could be used as the main tank.
Old Apr 6, 2005 | 09:02 AM
Alviejp's Avatar
Alviejp
WillyB, what are the dimension of the tank you got under the bed? So, i can use that when looking around, might go that way instead of a rear mounted tank.
Old Apr 6, 2005 | 09:47 AM
WillyB's Avatar
WillyB
It is a stock Ford - fits between the frame rail and driveshaft. There is a notch in the floor of the bed for the filler neck, which sticks out through the left quarter panel.
It will work on any long bed, but you will need the mounting brackets and sheet metal "tunnel" for the box from a donor truck.
The only downside is that you have to be creative with your duel exhaust - either route it on the right side of the truck, or outside your frame rail.
That and you have to mortage your house to fill it - gas is up to $2.65 a gal here in California. I filled both tanks the other night and it cost over $100.
banjopicker66's Avatar
banjopicker66
Try searching the '61 - '66 forum especially. The frame dimensions are identical from '65 - '72. You can swap cabs and beds, with correct mounts points being interchangeable without alterations.
Details on making a rear tank for a '65 and '66 will apply all the way up to '72.
They should also apply for '61 - '64, but someone else will need to confirm that.
Old Apr 6, 2005 | 10:26 AM
4Cammer72's Avatar
4Cammer72
61 to 64 yes, the only difference is the front suspension. its a straight axle instead of ibeams
tlb
Apr 23, 2016 12:21 AM
pauljones
Apr 15, 2016 10:23 AM
51phil
29
Feb 28, 2015 12:37 PM
WVTOMMY
Aug 8, 2011 12:21 PM
uc4me
39
Aug 23, 2006 11:08 PM
