I can't seem to locate the slotted mount for my generator - the upper one that allows for tension adjustment for the belt. I'm guessing that I turned it in by mistake when I returned my core piece.
Any thoughts on the best way to replace it? Carve one out of steel...swap shop, etc.
Well from ur info I see you have the same truck as I.. Are U install a Gen or a Alt? If it is a Alt you can use a unversal Adj top bracket as in mine.. Look in my picks and you can see.. if it is a Gen U can use the same braget but you will need to bend it a little so it will line up right
Mad - I didn't know there was a universal bracket available, I'll have to look into that.
58Ford - I might take you up on it if I can't find one locally.
Guess I should have posted the engine....223....it would have been more clear.
Thanks guys.
