Cold Air intakes and Dusty roads
I just installed in my 2004 F-150 a Volant Cold Air intake (with the filter box).
I drive quite often bad roads (unpaved) and which have a lot of gravel and dust/dirt,etc..
Does this affect the air intake? Or should I rather stick to Ford's original air intake kit?
-- Second thoughts --
Free flowing intakes do allow more dirt into your engine, and if you travel alot on dusty roads probably another mod would be better for you. There is alot of articles on this issue already and I'll sum them up.. Free flowing intakes are great for the city driver-they give more horsepower and better mileage..but if you spend alot of time in industrial work zones or travel on dirt roads they may do your vehicle harm.
Wolfdog, Did you purchase the Ram Air Scoop with your Volant?I bought the ram air scoop and cannot get it to align between bottom of Volant air intake and the tow hook area where it is sopposed to bolt up.I have been unable to talk to anyone at Volant.I was wondering if anyone else is having this problem?
Again -- I took the Volant out, because I'm concerned about its filtering capability....I haven't seen any independent tests.
Wolf -
Check out http://www.bobistheoilguy.com/airfilter/airtest1.htm for more info on washable filters.
Steve
Steve
coolrydr
47
10-27-2016 02:03 PM
trucker01
16
05-10-2014 09:23 PM
