HELP! Just changes spark plugs and now have problems
Hi,
I was able to change 5 out of the 6 spark plugs on my 2000 ford explorer and now I have rough idling that drops to 500 RPM and is extremely rough to drive. There is slightly less acceleration than before and when I press the accelerator down far enought there is a loud knocking noise from the engine. please help. I don't want to screw up my car!!
Thanks
Thanks
I'm not sure about the 2000 model year but my 1996 requires double platinum plugs because the spark plug fires twice each time. If you used the incorrect or cheaper plug, that would give you problems. Why only 5 plugs? Did you gap the new plugs? You must always re-gap before installing. A crossed wire would be a viable reason for poor performance as well. retrace each wire to the correct plug. If none of this help re-install the old plugs to see if that corrects the problem. On occation, new plugs can be defective or have a cracked insulator. It also sounds like you may be new to wrenching. Did you apply anti-seize on the plug threads?
In any case don't drive it until it is fixed.
The "double platinum" is needed, because the plugs in opposite banks receive
opposite polarity spark, causing the GND and the center electrodes to erode.
Thanks for the input. I used Bosch regular platinum spark plugs. The plugs I took out looked like single platinums as well. I am going to AutoZone today to hook up their OBDII sensor and check out what's going on. Will it give me the exact problem(S) or just a general answer. Thanks
PS-I also gapped them properly to .054. I also did not apply anti-siezing to the plugs. What will this do? Thanks
Originally Posted by bwinterr
OK got back from AutoZone. The OBD computer said there was a cylinder 2 misfire. Which plug would that be that I need to look at / reinstall. What would be some pronlems associated with a cylinder 2 misfire? Thanks
First, with anti-sieze the plugs will never come out again. the dis-similar metals will fuse together. Pull them all and use anti-sieze.
#2 is the middle on the passenger side. Check the wire. You may have damaged it when you were working on it.
Bob,
Are you saying that the spark plug fires on the terminal end of the exhaust stroke. I don't understand how that could be. My understanding was that the plug fires twice, once in each direction(electrode to ground and visa versa) on each compression stroke.
We are going to go with a plug other than the Bosch Platinums and are also going to replace the wires with some Autolite or comparable ones. The car has a little over 50k miles on it, and so do the wires. The 6th plug wasn't replaced because we ran out of daylight and it looked like a pain to get to, even through the wheel well. Not using anti-seize was my idea, coming from a car-only background, it's use is frowned upon because of how it skews torque wrench performance.
Just back off on the torque spec by 3 lbs for the anti-sieze if you use the torque wrench. I simply palm the wratchet and tighten it as snug as I can. I have never had an issue that way and it's hard to get over 10#s of torque. Beside the fact that my torque wrench never fits where the plugs are.
Bob,
the exhaust stroke, and with the next rev of the crank, the first plug will be
on the exhaust stroke, the 2nd plug on the compression stroke. I hope this answers your question.
plug wire boots.....
jxlopez47
3.8 & 4.2L V6
02-05-2017 11:04 AM
noidea2015
Escape & Escape Hybrid
05-27-2015 03:04 PM
jonnybronco
03-14-2005 12:03 PM
