Synthetic ATF in the Aerostar?
Since I just bought my van and I am not sure the last time fluids were changed, I am changing them all. Is it a good idea to use synthetic ATF in the Aerostar (93, 3.0, 2wd)? I have used synthetic oil ( Mobil 1) in my Focus since 5k miles, have changed it every 5-7500 miles and the car runs fine and uses no oil between changes. It now has 40k on it.
So, besides the extra cost, is it worth putting synthetic ATF in the Aerostar? Anyone else using synthetic ATF? I like synthetics, I believe they are worth the extra cost. But before I do, I would like to know some other opinions.
Mobil 1 ATF is not Mercon V rated. If your transmission calls for Mercon V, then look elsewhere. Mobil 1 is great fluid, but their Mercon V rating product is still in the works.
From Mobil 1 email
A reformulation of Mobil 1 Synthetic ATF is in the works. It will meet Mercon V, Dexron IIIH, and Chrysler requirements. Timing? Later this year. The Multi-Vehicle ATF (synthetic blend) will satisfy Mercon V needs until then.
Bruce (Mobil employee)
From Mobil 1 site
Applications
For many GM, Ford and import vehicles. Approved for use in vehicles specifying:
Dexron III, Dexron IIIE, Dexron
Now approved for H specification, the latest GM Dexron III performance level
Mercon
Recommended for Allison C-4 and Caterpillar TO-2 applications
From Mobil site
Applications
Mobil Multi-Vehicle ATF satisfies Ford's new Mercon, V specification, Ford Mercon and General Motors’ Dexron-III or Dexron II specifications. Now approved for H specification, the latest GM Dexron III performance level.
Mobil Multi-Vehicle ATF is also acceptable in any Audi, Honda, Mazda, Nissan, Opel, Renault, Toyota, and Volkswagen transmissions that require a Dexron-III or Dexron-II type fluid.
Mobil Multi-Vehicle ATF is also suitable for use in both newer and older Chrysler applications where ATF+3 or ATF+4 is recommended.
NOTE: For automatic transmissions in Ford Motor company vehicles where Ford specification ESP-M2C166H or ESP-M2C138CJ fluids are specified, Mobil Multi-Vehicle ATF or Mobil ATF D/M is recommended. For Ford automatic transmissions that require Type F fluid (M2C33-F), Mobil ATF Type F is recommended.
From Mobil 1 email
From Mobil 1 site
Applications
Mercon
From Mobil site
Applications
Originally Posted by Fordboy49
What're other brands can we use safely?
TIA
Fordboy49
TIA
Fordboy49
http://www.exxon.com/USA-English/Lub...O_Mercon_V.asp
I use Amsoil Synthetic ATF in all my 5-Ford, 1-Dodge, 3-GM vehicles for several years with great results. See http://www.amsoil.com
The Royal Purple seems to have made a slight difference. Of course, it could just be due to the fact the tranny is happy to have a new filter and fluid in it, since what I pulled out was the original stuff!
What a messy job! The last vehicle I changed ATF in was my 95 Cougar and I forgot how messy it can be. At least the van has more ground clearance.
It really is easier to put it on jackstands, but yes, the Aerostar has plenty of ground clearance. That one thing I like about it. We used to use my grandparents yuppie Voyager, and if you don't pull out of their driveway right, it will hit the sidewalk, and scrape the bumper. The Aerostar clears it with ease.
And that's in California, where the roads are infinitely better then they are here in the Rust Belt ( PA) I laugh watching these people in ANYTHING that's been lowered try to negotiate our potholed roads, steep driveways and railroad crossings. I was behind a extremely low Ranger once at a rail crossing, he had to creep across it. Compared to some of these lowered trucks, my Focus looks like a minivan!
Lowering a 1"-2" truck is fine, if you don't plan on using it for really heavy loads. Anything more then that is just stupid, UNLESS you will only be using the vehicle for show. As a daily driver, I don't get it.
Lowering a car that much, when it's not done right ( which it usually isn't by many of these "Fast n Furious" wannabes) is stupid, dangerous and wreaks all kinds of havoc on the suspension and other components. Especially around here.
I have a VERY steep driveway and the short overhangs and extra ground clearance on the Aerostar are very nice. The Traction-Lok axle will be nice in the snow. The 'Star is the only vehicle we own that doesn't drag any pieces on the driveway if you don't take it at the right angle or a little too fast.
Correct. But in this case (93 Aerostar) the book calls for Mercon. If your Ford product calls for Mercon V, it will be specified on the dipstick handle.
