hi, i'm having a bit of trouble flushing my radiator, i've followed all the steps but the discharge is still brown and muddy. do i just need to keep repeating the process until it comes out right, or do i need to buy a flush kit? i've been just pouring water in it during that phase, would it make a difference if i used some "force" to move it through there, like a garden hose? the coolant is so murky that it takes forever to drain it. my ranger is a 97, 2.3 4 cyl auto tranny. any help is greatly appreciated. thanks and have a great day.
I also have this problem, I've used prestone's flush kit with the cleaner and the power flush and it is still coming out brown. I also use only distilled water. Any help?
I just keep flushing the radiator with distilled water until I get clear water back out. Then I fill the rad with distilled, run the engine until hot to exchange the coolant out of the block and then flush the rad again. A couple cycles of this is usually enough to get everything pretty well cleaned out. I then fill the rad with straight antifreeze and run it warm again to exchange with the block. After that I check the coolant and modify it to -30*F.
I haven't used the flush kits so I cannot offer any opinion on those. However, be wary of the powerflush deals at the quick lube shops. They blew some gaskets on my fiancee's car that would have been more expensive to fix than what the car was worth. (Labor to tear everything down to replace a couple o rings was unbelieveable) So we just put a couple bottles of stop leak in it and traded it in on a new car for her.
i flushed mine last weekend with a prestone flush kit and it took only 2 minutes to flush the old out. get the kit and and save the hassle for something else. MAKE SURE YOU REMOVE THE THERMOSTAT BEFORE FLUSHING...........
that method doesn't clean much of anything or flush out the old. get the kit. its $8.00
The method I use has served me well for years now and I have never had a problem of not cleaning out the gunk. I will admit that it is not the most time conservative method available, but I know it works. I recently inherited a 1979 Chrysler from my grandfather that had never seen routine maintenance other than oil changes. I used that method to clean the coolant system and 3000 miles later, the antifreeze is still clean & green. It is also important to clean out the reservoir and return line so that any gunk built up in there doesn't foul the new coolant.
I have reviewed the flush kits you've descibed and they use pressure from a garden hose to force water through the block to flush it. I achieve the same result, just not as quick.
