How much does the bed weigh?
Old Mar 24, 2005 | 06:42 PM
Craig5_12's Avatar
Craig5_12
I'm going to need to remove my bed in order to fit it in my garage. Anybody have any idea as to how much it weighs? Oh yeah, it's a 65 F100 long bed.
Old Mar 24, 2005 | 09:30 PM
tomsrod's Avatar
tomsrod
I don't know the exact weight, but it will take four guys, one at each corner, to handle it. It works even better if you can get two more guys, one at each wheel well. You won't want to just set it down. Set up cinder blocks and 4x4 posts or a good set of saw horses to place it on to keep it off the floor.
Old Mar 24, 2005 | 11:12 PM
comet's Avatar
comet
I moved a '64 long bed last weekend. My guess, 500lbs, maybe a little less. We had 5 guys for part of the move and 4 for the rest. It's a bugger, but we had to move it a long way! We took everything off the bed first to make it lighter.
Old Mar 25, 2005 | 06:13 AM
jowilker's Avatar
jowilker
I'd say no more than 300 pounds, I have moved them by my self, and loaded them with one other person. Four people would make it a lot easier to handle though. Can you remove it inside of your storage area? Stand it on the cab end with something under it. It takes up less space that way. I usually use 2X4s under one when I do that.
John
Old Mar 25, 2005 | 09:49 AM
taylor0987's Avatar
taylor0987
I've seen pictures of people using an engine hoist to lift the bed...
Old Mar 25, 2005 | 03:49 PM
FLgargoyle's Avatar
FLgargoyle
You mean your supposed to empty all the stuff out of the bed before you move it?! NOW you tell me!
Old Mar 25, 2005 | 05:37 PM
ZombieSlayer's Avatar
ZombieSlayer
I've used that method to r and r a bed on my friends f150. Gets some odd looks from passerbys
Old Mar 29, 2005 | 01:13 PM
Craig5_12's Avatar
Craig5_12
Thanks for the suggestions all, Once I get the dang four banger out of the garage it's time to do some real work on the truck! I'm thinking the rear brakes will be upgraded as it seems pretty easy to do, as well as a through and through cleaning of everything. Also will be installing disc brakes on the front! Lots of questions to come.....
rbell14
Sep 9, 2015 08:19 PM
VTX1800rider
Apr 8, 2014 07:41 AM
Splatts
29
Mar 10, 2013 10:29 PM
RIKIL
13
Aug 31, 2012 03:43 AM
merlin1926
Sep 5, 2003 05:08 AM
