Tranny Adjustment??
Old Mar 23, 2005 | 09:57 AM
jason47352's Avatar
jason47352
Tranny Adjustment??
I have a 92 Explorer that has developed a bad vibration when it goes into over drive ( right around 1500 rpm, just after shift for 2500 rpm or so, so I believe that this is in overdrive) Is this due to a loose band and if so, can I adjust this and where is the adjustment (diagram). Or am I completely off base with this. Also fluid level is right( was a quart low)
Thanks
trjcwilkey@spitfire.net
