Differential Compatibility
Old Mar 18, 2005 | 07:05 PM
77_eeehhh's Avatar
77_eeehhh
I am currently restoring a 77 stepside with a 400 (not cc) engine, 3 speed hurst shifter. I was wondering if anybody could tell me what would be the best differential from a scrapyard which would be compatible with this. Also, which gear ratio would be best suited.
Old Mar 19, 2005 | 12:30 AM
Mil1ion's Avatar
Mil1ion
You didn't type in enough info for people to answer.
What rear does it have now?
What is the truck going to be used for ?
Size tires?
Old Mar 20, 2005 | 04:11 PM
77_eeehhh's Avatar
77_eeehhh
The rear thats in it now is the original from the six cylinder.
I plan on using the truck for weekend driving (hwy/city) also want to have lots of speed. Tire not yet purchased
Old Mar 20, 2005 | 04:30 PM
biz4two's Avatar
biz4two
Without knowing all the details, I suggest the following:
1. Ford 9" rear axle with 3.50 or 3.73 gears (31 spline at a minimum)
The reason for picking this diff, is simple. It really is a strong rear-end and also easy to work on. Try and find one with a limited-slip or locking rear.
Good luck with your rebuild.
Old Mar 20, 2005 | 05:17 PM
F150daniel's Avatar
F150daniel
"with a 400 (not cc) engine,"
Is it an?
F100
F150
F250
F350
Where are you located?
Old Mar 20, 2005 | 05:31 PM
77_eeehhh's Avatar
77_eeehhh
it's a f100. thanks for the help biz4two.
