headers
Old Mar 17, 2005 | 12:06 AM
yahwehrider's Avatar
yahwehrider
headers
what kinda problems should i look for when installing headers on 1975 f-250
460ci looks awfull close on the sterring box side.
rick
75 f-250 460ci/c-6
Old Mar 17, 2005 | 09:36 AM
73Custom's Avatar
73Custom
My '73 F100 2wd 390 was kind of a pain to get the headers onto. I had the pickup raised on a hoist and had to loosen the motor mounts and jack up the motor. Then the drivers side slid down from the top and the passenger side slid up from the bottom. On the passenger side I had to remove the starter to get the header in, but reinstall the starter with the header in place but not bolted to the engine - kinda tight there... I would recommend a heat wrap/shield on the starter and good header gaskets - I like the NAPA gaskets. Then be sure to retighten the header bolts several times in the first week of driving and you should have no leaks.
Marty
Old Mar 18, 2005 | 03:19 PM
fordfury469's Avatar
fordfury469
is that a two wheel drive or 4x4,
Old Mar 18, 2005 | 05:32 PM
yahwehrider
75 f-250 camper special 2x4
Old Mar 18, 2005 | 07:36 PM
fordfury469
oh i see if they are for your pickup then they should fit. ive never done a set on a 2x4 so i wouldnt know, i guess im no help
Old Mar 21, 2005 | 08:10 PM
460me's Avatar
460me
In just put in a set of Doug Thorley on my 79 460 2wd(tralier special),raised the front end off the gound and had to remove the starter.No problem with the sterring box.Had to move the bracket that holds the brake lines,tunred the bracket.Driver side easier than pass side.Took about 4hrs. with beer breaks.
