Motorcraft 15w40 Superduty Oil
Jeff- I'll probably get flamed for this response (it won't be the first or last time) I'd go with the Mobil1 synthetic 5w40- IMO You will be very pleased with how your 6.0 runs with it... This opinion seems to be shared by a lot of 6.0 owners. I've had my 6.0 for over two years & 50,000 miles and it runs better than the day I bought it new!
Buy the Mobil1 on sale at any of the larger auto stores- Go 5,000 miles between changes and it will pay for itself with the typical 1 mpg increase- Good luck
Not to flame anybody but, the old Mobil One, while dual rated for diesel use, is not rated for the 6.0 PSD. It is rated for the 7.3 PSD. The new formulations of Mobil One which would be their 15,000, is also not rated for the 6.0 PSD. It has to do with the additive package, in particular, the anti-foaming agents. If you want the Mobil Synthetic, use their Delvac 1. It's the best oil out there in a synthetic. If you want to stay with a good dino oil like the Motorcraft, I would suggest finding Delo 400+. The + is the important part. It will have a good shot of moly for the barrier lube state. Test results have been darn good. Also, Rotella T turns in some good low wear metal numbers as well as Mystic. Mystic is one of those sleeper oils that nobody ever thinks about. It is under the Citgo flag now and can usually be had at a farm supply and is generally well priced. Motorcraft has been hawking their goods thru some of the Pep Boys. If you still want to use it, you might start there.
Seriously- Flash, glad to hear that you think it's the best out there- I've been very pleased with the operation and also had analysis which came out well. There has been recent discussion that the Delvac 1 isn't as easy to find anymore now that Mobil has increased marketing & distribution of the "Truck & SUV" label.
90pioneer
05-08-2011 09:00 PM
