chip or propane
If money isn't an option then I'd get both. But if I had to choose I'd go with the chip. Without one I don't know the actual improvement of propane alone. Quadzilla is probably the resident expert here on propane injection.
What have you done to your truck already? I'm guessing you have already gotten gauges, intake, and exhaust, right?
Choosing between a chip and propane? I could give a better answer if I knew a little more about your truck. For example, is it an automatic, or a stick? Are you happy with how it runs now, but merely want more power, or are them some characteristics you'd like to change? For example, shift points on an automatic.
If you're happy with everything else, but merely want more power, then propane can/will give you more power than a chip. As was asked earlier, do you already have the ground work done, by getting a downpipe and exhaust, gauges, and intake?
I'd go with a tuner first. I would also choose a tuner that allows you to have modified tunes downloaded from the internet for when you decide to go with propane. This sure beats having to send your tuner in!
The Predator is the only one that I know of that performs these functions.
the details
well I have a 2000 f-350 six speed, gauges, k&n intake and the whicked wheel. I will be going with a 5 inch exhaust and a four inch down pipe. Looking at the computer controlled propane injection from msd. Planning on roasting the wheels off mustangs, firebirds, prep, jock, ferternity cars ect. you know the boys with there cute cars that think they are so hot **** ha thay got nothing on a truck and i want to prove it.
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-06-2014 11:27 PM
SoundBuys
11-05-2004 11:27 AM
94f2507.3td
10-17-2004 04:04 PM
96ford4x4turbodiesel
27
03-10-2004 01:05 AM
Strjock81
01-03-2004 07:25 PM
