Uh Ohh major problem
Old Mar 10, 2005 | 10:12 PM
wakywaco's Avatar
wakywaco
I was looking over my 55 today and discovered that this thing doesnt have any vin numbers on it, or atleast not that I can find. They are supposed to be on the drivers door right, What am I to do now. I bought it from a friends dad who has owned it since 84 and hasnt touched it. Am I missing something here, and if not, what can I do to get Vins back on this truck.
Steve
Old Mar 10, 2005 | 10:22 PM
55forder's Avatar
55forder
When I got my truck the V.I.N. numbers werent anywhere on the cab either.
Call your local Highway Patrol, and ask them what you should do. I did that, and in about 2 weeks, they sent an officer over to check my engine #s, and my frame #s to make sure all was on the up-and-up. A week later, the officer came to MY house, and riveted my new V.I.N. #s to the inner drivers side of my door. Because the truck had been sitting for so long, they had to issue me new #s.
Call your local CHP, and ask them what you can do. They should help you out.
Hope this helps,
Rich
Old Mar 10, 2005 | 10:28 PM
wakywaco's Avatar
wakywaco
Rich, the truck has no motor nor door vins. Where on the frame can I find the vin number?
Thanks
Steve
Old Mar 10, 2005 | 10:33 PM
Goobzilla's Avatar
Goobzilla
The VIN should be on the passenger side frame rail. It's there probably, may need to wire wheel the frame to see it. If you have the front clip on, you may not be able to get to it.
Ron
Old Mar 10, 2005 | 10:40 PM
55forder's Avatar
55forder
Its going to be on the passenger side top of frame rail, close to the firewall. Wire wheel the area, its there.
Rich
Old Mar 11, 2005 | 12:49 AM
Earl's Avatar
Earl
A little caution on the location. I remember that a couple of the fellas found theirs on the driver side rail but I can't remember the year for sure. At any rate, as you guys mentioned, it should be on the top of one of the rails somewhere between the firewall and the front axle.
What about the VIN in the glove box? I know the memory is going but I was pretty sure 56 was the first (and only?) year to have the VIN on the door post. Prior to that I thought they were on a tag in the glove (dispatch) box.
Old Mar 11, 2005 | 01:25 AM
Fomoko1's Avatar
Fomoko1
My 56 had the # on top of the front left frame rail between the fire wall and the front axle.
Old Mar 11, 2005 | 07:28 AM
fatfenders's Avatar
fatfenders
Couple things,
I think you are correct on the VIN is on the glovebox door prior to 56.
How deep is the stamping normally? Could a guy cleaning up the frame rails during an IFS install (or two), inadvertently remove the numbers?
And is theft protection/recovery the original reason for the frame stamping? I know the dash tags on military vehicles will sometimes "fall off", and are accidently re-attached to a truck that has new seat cushions and a better heater.
Old Mar 11, 2005 | 07:35 AM
Jacques's Avatar
Jacques
My 55 has it riveted on the inside of the glove box door on a builders plate (for lack of a better term). My 48 had it stamped on the drivers side rail, if I remember right, it was on the top. I wire wheeled both sides until I found it & then had a Highway Patrol Officer verify it so I could register the truck.
Regards,
Jon
Old Mar 11, 2005 | 09:28 AM
wakywaco's Avatar
wakywaco
Yep, I panicked for no reason, its in the glove box held in by regular screws. What a relief. thanks guys. I thought I was screwed there for a while.
Steve
Old Mar 11, 2005 | 10:02 AM
fatfenders56's Avatar
fatfenders56
post script: I found the vin for my 56 on the passenger side frame rail above the crossmember for the core support. FYI it's a good idea to photograph the vin before you start cutting things up
Old Mar 11, 2005 | 11:40 AM
imlowr2's Avatar
imlowr2
Actually, the most important part is that VIN# on your DMV registration matches. The tag on the door beam is easily purchased and you can even stamp the correct VIN# into it. May not be original, but it'll work.
Sudsrat
1966 - 1977 Early Broncos
Apr 30, 2023 08:42 AM
smkf100
Sep 23, 2009 07:18 PM
flyingtexan
Dec 2, 2006 09:38 PM
65SteveO
Jan 26, 2006 06:29 AM
Steve A
31
Nov 4, 2004 01:49 AM
