I was just curious b/c i read on another thread on this site that the reason these truch sit higher in the back in the first place is so they are more level when hauling a heavy load.
and according to BILLC it does change the payload.... by a pound or 2
The truck sits higher in the back which will bring it to level with the added load. If the truck sat level the added weight would cause it to sag in the rear. Could affect headlight aim.
Subtract the weight of the spacers and you'll have your revised payload.
Spacers are unsprung weight and will have no effect on payload other than the tire's capacity to support the weight. Pretty funny response, though!
I would argue that any load in the back that affects the rear ride height will affect the headlight aim. Having the front level doesn't change that fact.
What could be affected would be your handling & stopping ability caused by the rear end sagging below the front when carrying a heavy load.
