hunt for that dropped axle
Old 03-09-2005, 10:48 PM
six7seta's Avatar
six7seta
six7seta is offline
well ive been searching for a dropped front axle for my 52F2.. ive seen alot for 53 and up... but never anything for the 51-52 years. can i use a 53?
Old 03-09-2005, 11:40 PM
46yblock's Avatar
46yblock
46yblock is offline
There is an outfit that will restructure your current axle to your desired drop. I will look and try to find them.
Old 03-09-2005, 11:59 PM
46yblock's Avatar
46yblock
46yblock is offline
Sorry but I couldn't come up with the company. They advertise in rod mags. Maybe someone else knows of them.
I believe you can use an axle from an earlier ford with transverse springs, and weld on spring perches. I did. It is a little hassle but not bad. Also need to have machined into the boss allowance for lower shock mount.
The axle I used was from Magnum and was tubular. It looks like all they offer now is I beam.
Old 03-10-2005, 12:46 AM
av8ford's Avatar
av8ford
av8ford is offline
This should do it . . .
http://www.roadsters.com/axles/
Mike
Old 03-10-2005, 01:04 AM
46yblock's Avatar
46yblock
46yblock is offline
Mike, thanks for bailing me out. I added the site to my favorites.
Mike
Old 03-10-2005, 07:29 AM
Christopher2's Avatar
Christopher2
Christopher2 is offline
www.cenpen.com
http://www.classictruckshop.com/cpp.asp
Both have a new axle for the price of getting a used one dropped.
Old 03-10-2005, 07:10 PM
six7seta's Avatar
six7seta
six7seta is offline
sweet.. you guys rock! an endless thanks!
Old 03-11-2005, 12:13 AM
PanelBeater's Avatar
PanelBeater
PanelBeater is offline
One of the companys that I have heard of is called Mor-Drop
Mor-Drop
600 29th Ave., Dept. CT
Oakland, CA 94601
(510) 261-1888
They take your axle and heat and stretch it for the drop. They have been in buisness for decades...
Old 03-11-2005, 12:18 AM
PanelBeater
http://www.classictrucksweb.com/tech...traightxxlebb/
Here is a link that explaines some of the options.
Old 03-11-2005, 12:29 PM
fish-albuq's Avatar
fish-albuq
fish-albuq is offline
while we're talking about the dropped axle. i have a stock front axle now. if i put a 3" dropped axle, does that really make it a problem for bottoming out and scraping? it sure looks to lower it awful low to the ground.
Old 03-11-2005, 12:39 PM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
three inches is a good drop, depending on tire diameter etc. In reference to Mor-Drop, I have used their stuff before with only minor complications. the thing to watch out for is the hole for the king pin. to drop these axles they heat then and stretch them to maintain correct width after the drop is added. the problem arises when the kingpin hole becomes elongated in the stretching process and must be rebored before installing the kingpin(s)
REDS52F1
06-13-2013 10:12 PM
OldSchoolRodz
08-04-2008 10:40 PM
six7seta
04-09-2005 09:11 PM
ahawes
07-15-2003 07:26 PM
selbyrk
06-19-2002 03:06 AM
Quick Reply: hunt for that dropped axle
