Intake Manifold Coolant Leak
Old 03-09-2005, 03:02 PM
woodya651's Avatar
woodya651
woodya651 is offline
Can the line from under the manifold be removed and plugged at the heater hose with no ill effect or will coolant run from the exposed port in the lower manifold? I cannot see where the coolant goes to, does it just sit in the manifold with no flow?
Old 03-11-2005, 04:07 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
I think that is the return for the heater core.
Old 03-15-2005, 07:34 AM
tomw's Avatar
tomw
tomw is offline
If you are talking about the 3/8" or so line from the tee in the heater hose, it will leak if disonnected and left unplugged.
Think about it for a second. If it were to fail to leak, then where would the coolant be flowing? It could only come & go thru the hose. Not likely. It has to flow thru somewhere or it is useless.
tom
