Towing truck home.
OOF! That brings up bad memeries ! Two weeks a go I towed a54 from Kansas to Colorado. I was lucky enough to have a friend with a nice big ford with a 460 and a flat bed trailer. unfortunateley we blew his tranny up in the middle of Kansas and had to call his dad to tow us back! Turned a twelve hour trip into 32!Iknow uhaul wants an arm and a leg for car hauler rentals, I had considered a tow dolly but you have to consider how old and neglected the rear end and wheel bearings are - ie, "will they lock up on me half way back?If you look in the towing section of the phone book some companies will tow out of state for something reasonable and then you won't have to mess with it at all!
I towed my 56 from Denver to Detroit with a tow bar. Disconnected the driveshaft and wired it up out of the way. Towed behind a 4.0L Ranger Supercab at 65 MPH without any problems, except you have to remember you can not back up. Removed the 56 front bumper and connected the tow bar to the frame horns. Attached a brake light to the 56 rear bumper with a long jumper to the Ranger trailer tow harness.
See if you might have a friend or a friend of a friend who might rent one to you. I just towed my 54 across town with my friends trailer. Of course he did not charge me. I have people ask me if they could rent the trailer from him. He did rent out his trailer to them for a very reasonable price and there was usually no time limit to the hour on returning it.
i towed mine from maryland to north carolina with a 390 big block and c6 under the hood and the bed full with a uhaul tow dolly distance of almost 300 miles no problems with a explorer sport trac ran 65 to 70 on I95 (didnt want to get run overlol) i just made sure i had a spare(2) and checked the rear and pulled the driveshaft and no i wasnt doing my impersonation of a whell chock in the pic
Fuzzy,
Just bite the bullet and by yourself a trailer.
I went in halfers with a friend. He needed the trailer for his race car and I needed the trailer for my '52 Panel and other trucks that I will buy in the future. The trailer will always come in handy.
Bought the trailer from the manufacturer directly. It's an 18ft extra wide trailer from Carson Trailers. Wooden deck, dropped axles and electric brakes. Paid around $2k total ($1k each). Drove down to Los Angeles and picked it up. Saved about $600.
<A[ src="http://img.villagephotos.com/p/2004-10/863544/DSC03118.JPG" img]<img>
Couldn't tow it with a Ch*vy. The Navigator is nice. It comes standard with an air ride suspension. It adjusts automatically to the load. The Panel weighs 3500 lbs plus the trailer. The Navigator doesn't even sag in the rear. Not bad for an SUV based on the 1/2 ton truck.
Ilya
Ilya
Fuzzy,
I know you know but just to remind you:
Tie it down securely on all 4 corners using good chains or straps. Check them everytime you stop. MAke sure your tow vehicle is compatible wiring wise with the trailer. If not, fix it ! In many states it's illegal to tow more than 2k lbs without electric brakes on the trailer. Make sure all lights work. Take along a spare and some way to jack up the trailer to change the tire. We've all seen trailers left on the side of the road because there was no spare. Check condition and air pressure in the tires. Put a not for sale sign inthe truck so you won't be bothered if you don't want to be bothered.
Be safe
Bubba
Be safe
Bubba
