Are all small block bellhousings Equal?
Old 03-06-2005, 11:31 AM
Campbell 56's Avatar
Campbell 56
Campbell 56 is offline
Well, equal as far as the trans mount pattern goes. I've got a Cleveland mated to an FMX and a C6 sitting on the engine stand. I'm also considering trashing those two and using a late AOD from an F150 (non-electronic). So, if I get a small block AOD trans, will it fit my 351C? And jsut what should I do about the flex plate and torque converter?
Old 03-07-2005, 11:42 AM
loudfords's Avatar
loudfords
loudfords is offline
The bellhousing will bolt up, and just use a stock or aftermarket AOD torque convertor, it is not engine specific. The flexplate is much harder, as the AOD was not a factory option behinde a Cleveland. What is the stock imbalance on a 351c flexplate? You might be able to swap to a 302 or 351w flywheel depending on the imbalance and the mounting dimensions.
Old 03-15-2005, 08:09 PM
Campbell 56
a bit more info on an AOD/351C setup
So I found a website with lots of info on AODs and the various engines. Seems that the AOD mated to 164 tooth, 28.2 ounce imbalanced flexplates among others. They even sell an adapter kit for the stock 351C flexplate to the AOD, it only costs $350 (!!!on sale!!!). I'm now on a quest to determine if I really need to get the kit. It includes new fasteners, an adapter fitting for the crankshaft, a few bushings and a very large rectagular plate with the tranny cutout in the middle. It's from CoanRacing.com. (I just looked again, it's back to the regular price of $384.25)
I'm wondering what the rectagular aluminum plate is for. They call it an adapter plate. It looks like a spacer to me, it's about 1/2" thick by the looks of it.
So, now I look for info on flexplates. I saw one tech article from a guy who put an AOD in his 70 something Mustang. The first flexplate he tried didn't work as it didn't locate the TC correctly and it wouldn't interface with the tranny fully. Spewed fluid all over and made a mess when he started it up! Not good.
351Cleveland C4
06-01-2014 08:03 PM
rsalter66
12-11-2007 09:13 PM
390fe
05-17-2006 02:16 PM
canadianfordman
05-10-2002 05:44 PM
jdbanks
17
09-29-2001 06:11 PM
Quick Reply: Are all small block bellhousings Equal?
