For maximum ground clearance, without modifications to suspension, what is the largest tire/wheel rim that I can buy. I plan to buy a set of steel spoked rims, in the largest size that will fit and put mudders on the rear. The truck will be used on a farm. Also, where is the best place to buy the rims?
You did not mention if it is 4x4. I noticed at the magazine stand the other day that one of the off road mag's had a chart for just about all makes and models listing what fit's stock trucks and what would be required to go up in tire sizes.
I will stop by the mag stand after work this evening and let you all know. I did notice that for f150 4x4's 73-79 the largest you can run and still have the suspension cycle without rubbing is 32x11.50x15. I have 33x12.50's and I have rubbing problems in the front.
i have 265/70R15's on my 2wd, no problems. they are about the same size as 31s. i would probably recommend 31x11.5 or 31x12.5 for the rear...those should fit fine, and you'll get more flotation. you can always go skinnier up front.
If you have a 4x4 you can check out Four wheeler magazine for the month of April. They have a chart that shows the max tire size you can run on just about every make and model as well as what is required to go up in size. They have a web site that it may be on but I have not checked. Oh the web site is fourwheeler.com Hope this helps...
