2002 F-150 Rear End Swap Question
I have my 2002 XL F-150 6cyl sitting in my driveway with a nuked rear end. The pinion is nuked due to a bad seal/bearing and cannot be removed.
I have been hunting for the entire rear end from local wreckers for a while now but is seems the axle code 27 or the 3.31 Non LS rear axle is hard to find due to seal/bearing issues. The ones that are available are high mileage and $1000.
My rear end has disc brakes. One wrecker said he has 3 drum brake versions from a 98 for $450.
My question is will the disc brakes from mine bolt on to the drum brake rear end assemblies from 97 and up F-150's?
What other options do I have?
Thanks in advance.
Thanks in advance.
85lebaront2
11-30-2015 07:42 AM
ferguson777
04-05-2003 10:03 PM
