I have a "4X4 Hi" light that comes on when I shift my in dash 4X4 selector **** to the "4H" position, but when I shift to the "4L" position, the amber light in the instrument cluster doesn't change, it still says "4X4 Hi". Is there a light for the "Lo" that mine isn't switching to or is this normal? Also, I can't really tell a difference when I switch to "Lo", and I'm worried that it's not switching at all. Any ideas or experiences with this fellas/gals?
You have to make sure the truck is stopped completely and in neutral. Look in the owners manual and it will tell you how to ****ch from 4X4 High to 4X4 Low. You should also feel a difference in the gearing of the truck in 4X4 low. At least my Screw FX4 feels different.
You should definately be able to tell a difference when in 4LOW.If after trying above suggestions and it still does not work, I would take in for repair.Keep us posted.Good Luck!
