Shift lever jumps 04 Explorer
Old Feb 28, 2005 | 09:08 PM
jmyotis's Avatar
jmyotis
Exclamation Shift lever jumps 04 Explorer
Sporatically the shift lever will "jump" like it was not porperly engaged. It is in drive when it does this. Is this something any one else has experianced? Should I report it to the dealer and have "fixed"?
Old Feb 28, 2005 | 10:07 PM
Steina's Avatar
Steina
CO River Rat
No. Yes, I'd sure have it looked at ASAP.
Steve
Old Mar 1, 2005 | 11:03 AM
robl's Avatar
robl
I have had this happen before as well on my 03. The only reason it has done it was becase I did not proberly put it in the groove for drive. The truck is in drive but then while you are driving the spring then pops it into the proper groove making it jump. Next time you put it in drive see if you can feel the groove with the lever. This groove prevents it from slipping out of gear and is held by spring tension on the lever.
centralNH
Jun 1, 2014 05:41 PM
Cdy1
1997 - 2003 F150
Jul 26, 2010 10:46 PM
learpilot
Jul 13, 2009 05:33 PM
jade97
Oct 10, 2002 11:51 AM
