Biodiesel in newer PSDs?
Old 08-15-2013, 01:44 PM
flainn's Avatar
flainn
flainn is offline
Originally Posted by Lin19687
Anyone know how the Bio mixes with Reg Diesel when Reg Diesel is IN the Tank already ?
Will it just mix as
They're completely miscible with each other, in fact if you're getting anything less than B100, it's already mixed with petrodiesel. Pumping it into your tank will ensure sufficient mixing.
  #107
Old 08-21-2013, 09:00 PM
Z-MAN's Avatar
Z-MAN
Z-MAN is offline
80,000 on b100 w/ 6.0 140k on truck one injector replaced if your filters are clogged ,your killing your injectors,your using crappy under converted fuel, or your fuel system is filthy and the bio is cleaning it up. I have never even come close to clogging a fuel filter so my guess sub par fuel which is a 100% no-no in the 6.0. Good luck.
  #108
Old 08-25-2013, 02:26 AM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
Warning. some so called bio is beef tallow based not veg so do your research, here in Mt Vernon WA, they sell tallow blends, runs fine in my idi.
  #109
Old 02-24-2016, 07:56 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
Originally Posted by MRKnight
From my understanding the new ULSD that is mandated by 2006 will not have much fuel system lubricaton. Uisng as little as B2 or B5 is supposed to help with that as opposed to fuel additives. That's one of my reasons for looking for it. I know I won't save money on B5, in fact could end up paying a bit more per gallon.
B2 has the recommended lube value.
Tungsten
02-28-2021 01:53 PM
Shelstin
General Diesel Discussion
13
01-02-2018 05:26 PM
Bite N Hold
6.7L Power Stroke Diesel
12-04-2017 09:13 AM
2boxerdogs
6.4L Power Stroke Diesel
67
03-29-2017 05:37 PM
Baatzy
06-20-2016 07:26 AM
Quick Reply: Biodiesel in newer PSDs?
