what year is my engine!!
Old Feb 24, 2005 | 02:05 PM
danny allen's Avatar
danny allen
Question what year is my engine!!
I Recintly bought a 1987 ford f-250 with a..(i was told) 460 b.b. the problem i am having is trying to find out what year the motor is! i know they are all about the same but if it is older then 73' then some things are different
it is deffinitly a 460 with a 4-barrel carb. the only numbers on the top of the motor are the firing order and d5ve-9425-a3d
if any body can help me identify this motor i would greatly apreciate it!!
thanks,
Danny Allen
Old Feb 24, 2005 | 06:50 PM
cba135's Avatar
cba135
where are these numbers at? The engine block casting numbers are on the rear of the right side. The head numbers are on the ledge above the exhaust ports. D5VE means 1975 lincoln engine. You might want to check the other numbers just to make sure they match
Old Feb 26, 2005 | 07:12 PM
merc460's Avatar
merc460
Danny Allen
the number you posted is the intake part number cba135 is right its a 75 intake. look for the other numbers where cba135 mentioned they will tell more about the block and head combination
Old Feb 28, 2005 | 11:02 AM
danny allen
i put plugs gaped at .034 because i thought it was a 73 but now it runs better! any explainations?
Old Feb 28, 2005 | 05:07 PM
cba135's Avatar
cba135
73 heads had 91cc combustion chambers, 75 heads have 96cc. that might have somthing to do with it
Old Mar 1, 2005 | 04:33 PM
danny allen
i still dont under stand why this is making it run better?
when it is cold i run the battery down tring to get it started but when it is hot it starts up with barly a full turn!
any help????
Old Mar 1, 2005 | 05:03 PM
4x4dump's Avatar
4x4dump
you said in your other post you have a points dis. that is why it runs better with smaller plug gap . electronic ign. puts out a stronger and hotter spark. stating problem sounds like your carb. choke stuck or not working? gas draining out of carb over nite? good luck
Old Mar 3, 2005 | 09:55 AM
danny allen
Smile Thanks !!!!
Thanks guys you have all been a big help! and i am pretty sure it is a problem with the carb. it has a manual choke hooked up but i am still trying to figure out the finer points off adjusting it! what causes the gas to drain out of the carb?
any ways thanks!
what do you think the timing should bee set at?
Old Mar 4, 2005 | 12:48 AM
Bear 45/70's Avatar
Bear 45/70
any help????
Sounds like the chokes not working. Try pumping the gas while cranking when cold and see if the extra fuel makes it start easier.
Old Mar 5, 2005 | 05:20 PM
danny allen
it does start better when i pump the crap out of the gas peddle. it has a auto choke on it but it is not hooked up it uses a manual choke it dont know what wire to hook up the auto with.
do you guys think i need a new battery it shouldint drain dead in three times.
thanks
danny
