dead-spot in acceleration
Old 03-24-2005, 06:17 PM
FTK560's Avatar
FTK560
FTK560 is offline
Exclamation dead-spot in acceleration
I have a 1986 Ford Bronco II 2.9 auto. The problem is when accelerating I have to accelerate slowly. As long as I push the pedal slowly I can get up to 65 or 70 mph, but if I push hard at all it has a dead spot. Pushing harder just makes it worse. It doesn't just do it on take off, if I am cruising at 45 mph and want to be at 55 mph, I have to do it slowly, and not push too hard. I have changed throttle positioning sensor, EGR valve, fuel pressure regulator, coolant temp sensor, map sensor, oxygen sensor, fuel filter, and rear fuel pump, new tune up, plugs, wires, and distributer cap. Any ideas? Thanks in advance.
Old 03-28-2005, 01:35 PM
tomw's Avatar
tomw
tomw is offline
Pull the codes?
Leaky intake manifold?
Fuel pressure checked?
The MAP and TPS tell the computer to jazz up the injectors when you push on the gas pedal, just like an accelerator pump in a carb. Something is missing... either the TPS needs to be adjusted, the fuel pressure or flow is low, the MAP is whacko, or rats, just had a senior moment.
Any way, you are not getting the.. AHA, injectors are plugged up and just can't flow the fuel. (brain kicked back in) ... proper fuel flow to make up for the 'lean' caused by opening the throttele.. air will accelerate better than gasoline, so you just add some extra to 'adjust' for the flow properties. That's why you see the puff of black smoke when people accel onto the freeway, or kick-down to pass other vehicles..
tom
xjcamaro89
2004 - 2008 F150
19
12-20-2015 06:25 PM
northwindone
Modular V10 (6.8l)
06-09-2015 12:27 PM
JRSutton
09-21-2012 12:45 PM
Firefighter 1406
1997-2006 Expedition & Navigator
10-19-2011 11:51 PM
bayou barataria
1999 to 2016 Super Duty
22
02-13-2009 04:36 PM
Quick Reply: dead-spot in acceleration
