Headlight failure
Old Feb 20, 2005 | 02:51 AM
wildhunt57's Avatar
wildhunt57
Question Headlight failure
I had a 1989 F150 and I currently own a 1991 Explorer.. I have had the same problem with the both of them. After about 20 minutes of driving, the headlights begin to shut dowm, which is real fun when traveling at 60-70 miles an hour... Since this same problem has happened with both models, I am hoping that someone out there knows if this has been a common problem with these pickups and SUVs.. Any help will be gratefully received.
Old Feb 20, 2005 | 06:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
