96 aerostar sliding door
Remove the inside door panel and window trim to be safe 'That upper window trim is easy to crack"
You will see a rod that runs along the midle from the inside door handle to the latch. Hold the rod in the middle with some pliers and yank it back hard.
The cause is the plastic clip that hold's it broke or the ro connection came off up front or the rear.
Thank you so much. we got it open and then sprayed it really good. now it opens. and all we needed to do to get it to open from the outside was put a piece of cardboard on the plastic part that goes to the outside handle and now it opens great from the outside and inside. thanks again
fred white
03-24-2003 08:51 AM
