U-Haul car transport
I also posted this on the towing forum but thought maybe the Expy owners would have some first hand experience.
Sunday I had to go rescue my Son and his car, a 96 Crown Victoria. He was
about 110 miles away and his car would not stay running and making a
terrible noise. It is a constant noise a very loud clanking type sound. He
said will slack off at highway speeds if he backed off the throttle
slightly. He did not notice any loss of power. I have not started to
investigate what the cause is, it is nothing the jumps right out just
looking under the hood.
To get it home I went to the local U-Haul because it was close and open. We
got the car up on the trailer with no problem and tied down OK. What I
noticed as soon as I got on the interstate I realized just how easy this
setup would start to sway. Maximum speed I traveled was 55 to 60. Since the
back of the Expy went down over 2" and I know that 600 lbs tongue weight
drops it 2" inches. I have measured it with a known weight.
Is it just the nature of these car transports? I have a 8 wide 14 foot long
utility trailer that I pull that has never started to sway. The most the
utility trailer and load has weighed is approximately 4600 lbs total and I
guess the car transport and Crown Vic was about 5500 lbs. Anybody know what
a 96 Crown Vic weighs.
So I guess my question is was this a bad trailer or typical of a U-haul
trailer?
Bob W [FL]
99 XLT 4x4 W/ factory tow package
trailer?
Bob W [FL]
I didn't notice any swaying when I used the u-haul car trailer to haul my bug around. Then again, that car weighs a whole heck of a lot less than a CV. Could be that the tires on the trailer were bad, i.e. out of round or bent. The only problem I had was that the ramps kept coming out because the tab to keep it secure was broken. I had had to stop every 10 miles or so to push it back in.
Originally Posted by PaulC
I think a Crown Vic weighs about 3,700.
I would wonder if the tongue weight was what you estimated it to be.
***DON'T TRY THIS UNLESS YOU'RE DESPERATE/CRAZY/BOTH!!!***
Last week, my dad towed my Expedition 156 miles on a U-HAUL car trailer. The trailer swayed TERRIBLY at 60mph...but eased off when dropped back down to 55mph.
He was towing it with his 96 GMC 1/2 ton 4x4 (short-bed/standard cab) pickup.
My step-dad and I loaded the Expy onto the trailer the day before - with a chain hoist...it wasn't easy getting it lined up - the trailer wasn't meant to haul anything that heavy or wide (I'm talking what appears to be a compact car trailer) - after the Expy was loaded and tied down, I noticed the warning on the fender - gross weight must not exceed 4000 lbs!!! Can you imagine how I felt after reading that? I've got a 5500 lb vehicle on a 2100 lb trailer - 7600 lbs gross - nearly double the "DO NOT EXCEED" capacity. When Dad arrived the next morning to tow it back to "his neck of the woods"...he said, "it looks like a duck sittin' on a june bug"
He was concerned and so was I, but we proceeded to tow it the 156 miles and it did fine, except for wagging awful at 60mph. I had to radio him a couple times to tell him to slow it down! We made it there, unloaded the Expy at the Ford garage so the engine can be swapped and I towed the empty trailer back home with my wife's Explorer. The Explorer didn't seem to know the trailer was behind it...towed fine.
Well after reading all the replies, which I thank everyone for, I don't have a definite answer. I posted this on a couple of boards/forums. The common item that came up the most was a bad trailer whether it bearings, tires or what ever. The hitch height was not above U-hauls recommendation, but might have been slightly low as the trailer when loaded was a little nose down. I feel confidant that I had a minimum of 600 lbs tongue weight and most likely about 650 lbs. Also I had only the normal amount of air (35-36 PSI) in the rear tires of the Expy and not the max (44 PSI). Also I did not check the air pressure in the trailer tires, the tires did not bulge with the load on so I felt that they were OK.
Again I thank everyone for their input. I feel that most likely the problem was a combination of things. A trailer that was less the perfect and to little air in the rear tires of the Expy also the loaded trailer was not level but slightly nose down.
Bob W [FL]
99 XLT 4X4
Bob W [FL]
99 XLT 4X4
waystro
17
04-01-2015 09:20 PM
DPDISXR4Ti
22
12-20-2012 08:57 AM
PalaniRides
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
21
05-06-2011 07:56 PM
bobfl
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-18-2005 06:24 AM
jpeckinp
13
01-20-2005 06:59 PM
