98 Expi Theft light
98 Expi Theft light
I removed the battery cables to clean them because they were dirty and the truck didn't crank when turning the key only the fast clicking like a low battery or bad contact. After re connecting the battery the theft light blinks rapidly when either of the 2 sets of keys are used to turn on the ignition and the truck won't crank. If the ignition stays on after a few suconds there is a beeping sound from under the passenger dash. Also, neither remote will lock the doors nor will the panic buttons work but the unlock button will. When the remote lock button is pressed the only thing happens is a clicking under the dash near the radio. Both sets of keys were working fine as well as the remotes when the truck was last used 2 days ago. I'm thinking the removal of the cables may have caused the problem. Is there a reset that needs to be done to get it started?
Paul98038
1997 - 2003 F150
12-31-2019 03:57 PM
JRinSpokane
1997-2006 Expedition & Navigator
02-20-2016 09:34 AM
kcolg
Electrical Systems/Wiring
03-11-2015 10:08 PM
