Roll-Up Rear Window
Old Feb 12, 2005 | 05:42 PM
F250 Ranger's Avatar
F250 Ranger
Roll-Up Rear Window
How much work would it be to put a rear window and guts from a Bronco into the rear window slot on a '78 F250. I know that there would have to be some fabrication work for a cover shroud and the track would have to be installed, but would the window fit or is it too samll?
Old Feb 12, 2005 | 05:57 PM
GeneStoner's Avatar
GeneStoner
ANYTHING can be accomplished with enough will and money.
Old Feb 12, 2005 | 06:07 PM
ranger429's Avatar
ranger429
Why not just take your old glass to a glass shop let them make it the same except on the lower end make it a little longer so you can mount a slide bracket. Then all you would need is the proper rubber to seal. Sounds like a pretty simple job to do really. I know there are aftermarket kits for the newer trucks but not sure for our era.
MrHandsome
Dec 16, 2016 09:01 AM
6 or 10
Aug 24, 2015 08:02 PM
gabes
May 8, 2015 09:12 AM
sauce216
Mar 22, 2013 04:05 PM
Fxxer
1997 - 2003 F150
May 10, 2007 02:16 PM
