More power for 93 Lightning
That would be tricky, a stock 03 has 380hp /450tq whereas a 93 has 240hp and 340tq
even if you just added a supercharger, if you figure a 40% boost in hp you would still only be at 336hp. And thats just for a strait line. Here is the SVT site and the comparison between the 93 and 03 hope it helps. SVT Lightning
even so, I would still like to know what could take me there, for instance what cams are good to add on, whether or not i should convert to mass air, what kind of heads are the best, what supercharger will give me the most hp, what fuel upgrades will give me the best control and what computer chips or electronic devices will add extra power
A blower, headers, and traction bars and you're in GEN 2 territory.
My old blower setup (non-intercooled) netted me an 8.6 in the 1/8th, this was with Hooker headers, tranction bars, 30lb injecotors, and tuning software. On that run, I raced an 04 GEN 2 it it ran 9.0, it's best all day was an 8.98.
I'm running a Vortech SQ, and I haven't had my truck at a 1/4 mile track yet.
I added a intercooler from a Powerstroke Diesel (it was cheap too) and 42lb injectors since then. The very first tune I made for this combo get me 8.2 @ 88.6, which should be good for high 12's in the quater.
I have pics in my gallery of both setups.
hey blurry, i know im going to have to change to mass air to run more than 6 psi, whats the best kit to use and/or best way to do it?...thanks
The other thing I would recommend is getting a Tweecer and wideband O2 if you want to do your own tuning, unless you can find someone in your area that will dyno tune a speed density system and boost.
With the added power, these trucks need some tractions bars to keep the rear from braking, and a valve body and better trans pan will help the E4OD live longer.
GoldCo
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-28-2016 06:17 PM
Dean Bitner
11-25-2015 08:38 PM
pkracing03
08-09-2008 08:24 PM
lightning guy
10-06-2001 10:13 PM
1st, 2003, 351w, 93, boost, cam, f150, gen, head, intercooled, intercooler, lightning, powerstroke, svt, tick
