Push the button on shifter, but truck stays in overdrive, off light won't come on. Pulled button, checked with ohmeter, appears to work fine. Any ideas on this??? What colors are the wires and which plug do they go down to under dash? Maybe one is broken, if I knew color code, I could check continuity!! Anyone had this same problem??? Thanks for help.
Problem solved. All three wires were chopped off and mangled in the tilt mechanism. Stupid way of installing by Ford. They routed them through the tilt instead of just over top where they can't get cut or squashed. Thanks guys.
