speedometer issues
speedometer issues
My speedometer on my 84 f 150 w/ cruise was jumpin and actin up so I pulled it apart and greased the cable and then put it back together. Aint nothin changed...still jumps and is about 30 mph slow. The gear is fine. I'm wonderin if it's in the cruise counter thing or if its in the speedometer itself. Can anybody tell me what all's in the speedometer part itself and any possible fixes? Appreciate it.
speedometer issues
Similar problem with the speedo jumping and cruise control installed. I found that one end of the speedo cable was not fully engaged in the speedometer. I also double checked the other ends to make sure it was engaged at allpoints. It fixed the problem and could be the cause of yours.
-Kerry
-Kerry
