Rear differential cover torque specifications
Generally speaking, AFAIK diff covers are like valve covers, only needs to be tight enough to keep it from leaking. If you crank them down you're warp the cover.
Unless its something other than just a cover, like the differentials where the ring/pinion and whatnot are all mounted to half the diff that drops out of the axle, in which case it probably has an important torque spec.
If you're using RTV on the gasket, its probably finger tight, then wait a couple hours/overnight for the RTV to set up, then tighten down a bit more with the wrench.
newrider3
20
11-30-2020 01:47 PM
brian42
06-01-2008 01:42 PM
