Bassani or Magnaflow?
I am on the verge of buying a cat-back for my '04 screw. I have researched most all available choices and have narrowed it down to two choices. Both are lightning style forward exit and both have 3.5" tips. The bassani has 2.5" pipes w/ the magnaflow having 3.5". I found the bassani on another page for $585 but I can get the magnaflow for $450.
The man at the exhaust shop says he can do the magnaflow muffler w/ his pipes for $250ish plus tips but Im scared because it seems so cheap and I want quality even if I have to pay.
I dont mind spending the money because I want something different and stainless. Does anyone have an opinion on either or any pics I could see. Also I heard its better to get exhaust welded on rather than using the clamps?
I put a Magnaflow 2.5" catback system on my 2002 last year. I had a muffler shop put the system on and weld it to ensure against exhaust leaks. My only complaint is that the Magnaflow doesn't give me enough sound. I'm thinking seriously about putting a Flowmaster muffler on in the spring. My suggestion is to see get on both websites and listen to the sounds of each. The Magnaflow is a good system, just not enough VROOM for me.
I have run Bassani before, and I would again (probably will run the dual setup on my 04 when $ allows). The fit and finish is top notch, and it has a great exhaust note. If you would like to hear a soundclip of my past bronco with a Bassani kit, let me know. Drop me a PM or email. I also favor clamp on to weld. Not only does it allow for modification, but it flexes a bit more than a welded unit. Whether you realize it or not, your exhaust system does absorb some rotational forces from the road.
Grinder Man
1997-2006 Expedition & Navigator
10-10-2014 09:35 AM
BigGreen7.3swap
13
09-28-2014 09:21 PM
