Truck information
Old Feb 3, 2005 | 10:16 PM
southernpridecrd's Avatar
southernpridecrd
Truck information
How do i find out the information that the VIN tag numbers give on the inside of the door if it is not there and i do not have an owners manual? I have a 1991 F-150 thanx for the help.
Old Feb 3, 2005 | 11:08 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I think our trucks also have the VIN number on the dash on the drivers side, viewable from outside the truck thru the front window. Should also be stamped into the framerail somewhere toward the front.
Old Feb 4, 2005 | 02:58 PM
southernpridecrd
Yea i got the VIN number but i want the information thats on the VIN tag on the inside of the door like axle ratios, and that stuff.
Old Feb 4, 2005 | 05:12 PM
Kansas-Mike's Avatar
Kansas-Mike
I think if u take the vin to the Ford dealer they can help u....
Old Feb 4, 2005 | 07:52 PM
southernpridecrd
alright thanks for the help
Old Feb 4, 2005 | 08:04 PM
clipper1's Avatar
clipper1
The gear ratio should be on the tab bolted to the diff cover. Ther are a bunch of numbers on ther, but look at the lower left corner i think. But it will be on ther some were.
Old Feb 5, 2005 | 12:27 PM
southernpridecrd
Thats what i thought but here are the numbers i got and i can not figure them out so any help would be nice thank you.
5838A
55 88-0H07
and its a f-150 4x4 1991 302 5 speed
Old Feb 5, 2005 | 02:36 PM
SoCalDesertRider
That's a 3.55 ratio Ford 8.8" axle. The '3' in the ratio is probably covered by the bolt holding the tag on. If you see an 'L' between the '3' and the '55', that means it has a limited slip rear differential. No 'L' means it's an open diff. If you had a door sticker, the axle code would be either '19' or 'H9'. The H-code is for limted slip.
The rear gross axle weight rating is probably around 3800 lbs. I don't know what the GVWR would be.
The front axle is a Dana 44 TTB (Twin Traction Beam). I forget what the front gross axle weight rating would be.
If the trans does not have a granny low first, it's probably the Mazda M5OD. If it has a granny, it's the ZF.
Old Feb 5, 2005 | 04:02 PM
southernpridecrd
thanks socaldesertrider that helped out alot and it has m5od trans
'83f3fiddy
Jun 15, 2011 03:54 PM
HudsonJM
Dec 19, 2008 11:41 PM
rsaweger
Dec 18, 2007 07:35 PM
dhansen
Computer Chips & Tuners
May 17, 2007 01:02 AM
fordjr
Nov 25, 2001 01:15 PM
