ignition wire 77 f250
Old Feb 3, 2005 | 04:09 PM
cooklloyd's Avatar
cooklloyd
Hi ' I am having problems starting my truck. Put in new battery ,truck wanted to start then died.turned on headlights,no power,loosened the battery cable,moved it around then had lights. I went to start the truck and once again had no lights. moved cable and had lights. Is there a small wire thats to be hooked up to the battery? 400 engine thank you.
Old Feb 3, 2005 | 07:21 PM
Dealford's Avatar
Dealford
Sounds more like a bad connection or even corroded cables. Might be time for a major clean up or replace the cables.
AL.
Old Feb 4, 2005 | 06:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 4, 2005 | 04:44 PM
Franklin2's Avatar
Franklin2
I agree. You keep moving the cable around to make the lights work, so I would replace or clean the cable and make sure it's tight.
Old Feb 8, 2005 | 06:53 AM
cooklloyd's Avatar
cooklloyd
Thank you everyone, I found out the new battery had a bad cell. First I replaced the cable ends,charged the battery,went fine for the night,next day dead so parts sorce on the Queensway replaced the battery. Now I have a bunch of wires to conect,no licence plate lights,dash lights,horn,turn signals,E brake cable,front drivers signal replaced bulb,standerd steering need slave cylinder etc.
Old Feb 8, 2005 | 03:37 PM
Dealford's Avatar
Dealford
When you have a problem with any part of the lighting system, just start a new thread & the gang will jump right in to help.
AL.
VindexInjuriae
Aug 14, 2014 05:43 PM
dabaws
Aug 25, 2011 10:00 PM
RustyHighboy
Jun 7, 2011 03:07 PM
dcjohnson50
1983 - 2012 Ranger & B-Series
Dec 4, 2007 08:04 AM
peppy
Electrical Systems/Wiring
Jan 20, 2004 09:23 PM
