2001 explorer sport swap
Hi I have a 2001 explorer sport 2wd it has a 4.0L sohc I was told that a 5.0L v8 out of a older explorer would fit I would have to use all of the older explorer stuff to make it work. Is what I am wondering is will the current transmission bolt up if not what could I do for a transmission?
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
v8 explorer sport
Originally Posted by AlfredB1979
Use everything from an 01ish v8 Exploder. Tranny, engine harness, pats and key.....
KsCop
11-09-2014 12:38 PM
bflo1220
07-31-2014 12:22 AM
Mikeman
08-03-2013 11:04 PM
nascar88ford
12-16-2005 10:52 AM
