Fumoto Oil Drain Valve Yes or No! - Page 5 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
  #61
Old 11-25-2010, 09:53 AM
smokersteve's Avatar
smokersteve
smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Originally Posted by bismic View Post
My last UOA I split the sample into two bottles. One I sent in just as it was taken. The other I inserted a STRONG magnet in it for quite awhile. The anaytical results were essentially identical. I wonder how much good the magnet is under normal circumstances ..........
The difference is that when ever the stock bolt is removed there is metal on the magnet.
  #62
Old 11-25-2010, 09:55 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Originally Posted by Troy Buenger View Post
It keeps popping up for a good reason. Some people are on the fence to whether go with convenience (fumoto valve) vs magnetic filtering (oem drain plug). I'm personally on the magneted filtering because I remember when I changed the oil for the first time the magnet had some metal particles stuck to it that never made it to the oil filter. Maybe the magnet is there for the break-in period, but provides a peace of mind.
As one other person stated I have put an earth magnet right below the valve and I pull it off once the oil is draining.
  #63
Old 11-25-2010, 02:18 PM
bismic's Avatar
bismic
bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I hear ya, but it gets filtered before going anywhere important. Now if there were a large enough particle that could damage the pump (or plug the oil side of the oil cooler) - I guess that's a valid concern, but not very common issue (unless something is dropped during engine work). JMHO.
  #64
Old 11-25-2010, 07:09 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
I view it this way... International and the European company (actual designers) designed in the magnetic drain plug for a reason. I don't do oil analysis so I decided to keep it stock.
  #65
Old 11-25-2010, 08:29 PM
sandmanf250
sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
walmart drainpan
perfect.just lift it a bit to get the plug in.
  #66
Old 11-25-2010, 09:14 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
The second thing I did to my truck after the coolant filter was the Fumoto drain valve. It was worth the money and means no mess.
  #67
Old 11-25-2010, 09:36 PM
smokersteve
The metal is minimal that the mag pics up, but for me, I do not like the thought that those and other particles will go through the LPP
  #68
Old 11-26-2010, 06:51 PM
sandmanf250
fumoto plus
i love the fumoto and also installed the bronze replacement for the 6 mm plug that drains the water out of the fuel filter.got a big dose of water from a station with old tanks and have had to drain the filter 5 times in 2 days.pretty simple now. just turn it out with your fingers.
  #69
Old 01-01-2019, 05:42 PM
Gale Hawkins
Gale Hawkins is offline
Gale Hawkins is starting off with a positive reputation.
We added the Fumoto valve to the 2010 F-150 that we bought last summer on the first oil change and it was so nice to have when it came time for the second oil change.
  #70
Old 03-15-2019, 06:08 AM
steelandspeed's Avatar
steelandspeed
steelandspeed is offline
steelandspeed is starting off with a positive reputation.
Just got one F111S Short nipple for the 7.3, well pleased!
  #71
Old 03-15-2019, 07:28 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I've had one on my 04 for almost 15 years and never had an issue. Makes changing oil a breeze. I wish they came from the factory with one.
  #72
Old 03-15-2019, 12:52 PM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.
I have fumotos on the radiator, oil pan and both block drains, I love them.
  #73
Old 03-17-2019, 10:18 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
F350 1990 is gaining momentum as a positive member of FTE.
I rarely recommend brands, but Fumoto is decent quality....................use these fairly regularly on all vehicles ---- block drains, oil pans, etc..............
Readgriff
6.7L Power Stroke Diesel
08-13-2017 04:50 PM
LiquidSteam
2017+ Super Duty
08-13-2017 12:31 AM
jkey.bama
07-19-2017 06:55 PM
montauk1
07-29-2016 12:48 PM
barrelhorses
Modular V10 (6.8l)
21
02-17-2009 09:15 PM
Quick Reply: Fumoto Oil Drain Valve Yes or No!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
