Fumoto Oil Drain Valve Yes or No!
#31
#34
#36
#37
#38
#39
#40
#41
I use a 5 gallon spackle bucket to drain the oil on an '06 4x4 with stock 20" tires. The truck is high enough where I can get it under the plug with room to spare. Fills the bucket a few inches from the top. Put the lid on tight and dump at our town recycling (free). Then save for next change.
#43
Troy if you are finding metal in your oil pan after break-in you may have a major repair coming I have been told.
#44
I love the Fumoto valve and dieselsite.com coolant filter.
(Bought both items from dieselsite.com)
I use a large oil drain pan from Walmart (holds 18 - 20 quarts) - I can't remember. When done, I pour the old oil back into the empty gallon containers I bought my new oil in. I always keep a few old milk jugs or window washer fluid jugs around so I only have to fill each jus 3/4 full.
I run my truck until up to temp (all gauges). This way I know the oil is very fluid, warm and any particles that may be present are suspended. I do oil analysis every few oil changes and have NEVER worried about not having a magnet in/on my oil drain plug. If you have metal... then you have a problem with your motor or are not using a quality Racor made OEM oil filter.
I use the Fumoto valve without the nipple as using a hose just seemed like to much work and I did not like the "nipple" hanging down.
Enjoy.... it makes changing the oil on your truck a breeze (and cleaner). As well... you'll never have to worry about a stripped oil drain plug or worn out drain plug gasket.
Enjoy....
Enjoy....
#45
Received 1,446 Likes
on
This magnet comes on the engines for a reason. This is the first vehicle I've owned that had a magnetic drain plug.
