Fumoto Oil Drain Valve Yes or No! - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 01-31-2005, 06:12 AM
IB Tim's Avatar
IB Tim
IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
After the first changes....if you use gallon jugs, then you will have empties to fill from the Fumoto valve.
The first changes is the fun one, after that....
Old 01-31-2005, 07:34 AM
SBV45's Avatar
SBV45
SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.SBV45 is gaining momentum as a positive member of FTE.
Originally Posted by dsweger
Although I have a Fumoto on the way for the next oil change, you can buy an oil drain pan at Walmart which holds the old oil easily.... It even has a pour spout on the side to make getting the oil into other containers easy.
Been there and done that. It is slow going and can be messy. I spill less with the Fumoto directly into the jugs and you don't have to handle it twice.
Old 01-31-2005, 07:42 AM
Bushwhacker
Bushwhacker is offline
Bushwhacker is starting off with a positive reputation.
I used the Motoercraft 10W-30 oil and all I could get it in was quart containers. It will be easy to fill those quart containers back up with the Fumoto valve with the nipple! Easily wirth the $25 to not have 14 quarts of oil all coming at you at once! We have had one on our semi for years and I have always loved it!
Old 01-31-2005, 08:02 AM
dsweger's Avatar
dsweger
dsweger is offline
dsweger is starting off with a positive reputation.
The purpose in my thread was to mention that there IS a pan available that IS big enough to hold the oil.Notice that even though I have the drain pan, I still ordered a Fumoto valve for the next time...
Old 01-31-2005, 11:07 AM
Steina
Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
OSBUCKEY -
Check out www.fumotovalve.com
Steve
Old 01-31-2005, 01:44 PM
Antacus
Antacus is offline
Antacus is starting off with a positive reputation.
Looks like the 03-05 6.0L psd takes the "Product Code: Ford F111 N " valve. Anyone remeber off the top of their head if that is correct?
Old 01-31-2005, 02:02 PM
jackofalltrades
jackofalltrades is offline
jackofalltrades is gaining momentum as a positive member of FTE.
Off the top of my head, that sounds correct for the 6.0. But to play it safe, since I try not to use my debit/credit card on the net,- just call the guy, tell'em exactly what you are installing in. He knows quick which one you need. I think the nipple is worth it.
Old 01-31-2005, 03:06 PM
dsweger's Avatar
dsweger
dsweger is offline
F-111 is what I ordered and the "N" afterwards indicates that the optional hose nipple is included.
Old 01-31-2005, 05:36 PM
oriole
oriole is offline
oriole is starting off with a positive reputation.
Just had an Oil Guard system installed w/last oil change. Haven't been under the truck yet to see the set up. Can I use Fumoto with the Oil Guard system?
Old 01-31-2005, 06:05 PM
Steina
Steina is offline
CO River Rat
Oriole -
Unless the return oil hose was connected to the oil pan drain (not supposed to be), you can install a Fumoto valve.
Steve
Old 02-13-2005, 08:27 AM
regor1
regor1 is offline
regor1 is starting off with a positive reputation.
well you guys talked me into it. I just ordered one. thanks regor1
Old 02-13-2005, 10:50 AM
SBV45's Avatar
SBV45
SBV45 is offline
You won't regret it. I think it is the best extra money I have spent on this truck. Now if I could find the same type thing for the fuel/water separator.
  #28
Old 01-07-2010, 04:51 PM
Gale Hawkins
Gale Hawkins is offline
Gale Hawkins is starting off with a positive reputation.
We love the one on the MH and the kids do the draining but I do the filter after it gets cool. Last week we received one for the F700 429 engine but will wait for double digit temps to install.
  #29
Old 01-07-2010, 05:39 PM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
2nd best for me. Number one is a coolant filter. One saves mess, the other is peace of mind and happier equipment. ie; egr and oil coolers + water pump.
  #30
Old 01-07-2010, 05:40 PM
JReinert
JReinert is offline
JReinert is gaining momentum as a positive member of FTE.
Had one on my 04 for 80K, then moved it to my 06 and now have 160K on it. I wouldn't go without one.
Quick Reply: Fumoto Oil Drain Valve Yes or No!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
