Super Duty and winter driving
I gave up adding weight, just gets in my way for how i use my truck. Good tires, 4wd, and just take it easy. I've never had the patience to wear out a set of factory issued tires, either. They just suck. I've always preferred tires that are more aggressive than most, and try to find ones that have a "severe snow rating" as well.
Currently on my second set of ST Maxx Coopers, been happy with them. First set went 60k ish miles as well.
Curious, how much did your load weigh? I am projecting that my heaviest load will a family of 5 and a 10,000 5th wheel camper.
Rated load capacity wasn't the biggest problem, and you can have the tpms reprogrammed, but I've found tires rated for 65psi don't last very long if running heavy frequently. My fifth wheel is around 15k ready to camp, 2,900lbs on the pin. When i hit the scales ready to go i was at 6,900lbs on the rear axle, and wanted some fudge factor.
joegeds
32
08-29-2013 05:27 PM
Katmandu
12-05-2005 08:50 PM
