cleaning rusted grimey gritty parts /bolts - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Paint & Bodywork
Reload this Page >
Old 01-30-2005, 08:40 AM
sixgunkelly
sixgunkelly is offline
sixgunkelly is starting off with a positive reputation.
Hey All,I wanted to fill a horse tub up with something to let parts and reusable nuts/ bolts soak and get cleaned up.Anybody know of a good cheap detergent that'll get the job done???
Old 01-30-2005, 09:40 AM
Greg 79 f150
Greg 79 f150 is offline
Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.
A horse tub ? man, your old truck must have a LOT of bolts in it The parts washer tub is a cool piece of equipment to have. It has a little pump in the tank that keeps mineral spirits recirculating over the rusty stuff. Maybe some others will chime in soon with better ideas , good luck and jmo
Old 01-30-2005, 02:41 PM
460f250's Avatar
460f250
460f250 is offline
460f250 is starting off with a positive reputation.
I just do them a little at a time. Once they are cleaned and maybe painted I put them in a ziploc bag and label it for later. I have a hard time remembering where they all come from otherwise.
I put them in a pan that was for draining oil into when you change it. Use a little varsol or other solvent and they come pretty clean.
Old 01-30-2005, 05:39 PM
Aekisu's Avatar
Aekisu
Aekisu is offline
Aekisu is starting off with a positive reputation.
<cr>
I have used paint thinner (not lacquer thinner) for years. It has a slow evaporation rate and although flammable, doesn't have the flashback problems related to other solvents.
I have seen ads for an orange cleaner (similiar to the orange hand cleaner I believe). It is nonflammable. I'm not sure now well it works.
I have seen some recommendations for Sodium Hydroxide (caustic soda, lye, Drano, & etc.) for cutting grease. I'm sure it does cut the grease but I real concerns about the associate hazards and disposal issues. By the way, if you get sodium hydroxide on your skin, it will feel slippery. That's because it turning the oil in your skin and tissue into soap. True story !! Well, true chemistry anyways.
Old 01-30-2005, 08:43 PM
wicky's Avatar
wicky
wicky is offline
wicky is starting off with a positive reputation.
coca cola and wire brush
Old 02-01-2005, 10:44 AM
sixgunkelly
Ok ,well i have plenty of mineral spirits and i have nuts/bolts all marked in bags for different parts so i'll try one bag at a time in a small bucket or something.I thought maybe i could delute some Zerorust in a horse troft and put parts like the battery tray and stuff like that in there.
Old 02-01-2005, 11:25 AM
429 78 F100
429 78 F100 is offline
429 78 F100 is starting off with a positive reputation.
Question Cleaning larger pieces/Steering Box
I would also like any recomendations for cleaning up the larger parts(inner fenders, front crossover support ect.). I have the front of the truck completly apart. The only thing left is the frame and cab/firewall. The only places where there is oil is around where the steering box was, where it ran down on the frame crossmember and around the king pins. I plan on painting afterward.
And just a little off this subject anyone ever change the seals in the steering box? Easy or hard? Special tools?
Old 02-01-2005, 11:49 AM
Greg 79 f150
Wow, your in to a major restore it sounds like. I used simple green and purple power from my local auto store for my big cleaning. Both can be used in a pressure washer or scrub on with a brush and warm water , then rinse off . Might want to take your steering question to the " steering/ suspension " forum to get more replies on it. good luck on your truck
Old 02-01-2005, 08:32 PM
mr4speedford's Avatar
mr4speedford
mr4speedford is offline
mr4speedford is starting off with a positive reputation.
CLR takes the bolts down to bare steel. Taks 2-3 days. Castrol cleaner also works good for getting the grease off. -4speed
Old 02-02-2005, 12:10 AM
460f250's Avatar
460f250
460f250 is offline
For the bigger stuff I'm fortunate to have access to a bead blaster. Works like a charm and doesn't take too much time. Pretty much ready for paint after that.
Other stuff I just scrape and scrub down with Varsol.
Old 02-02-2005, 09:23 AM
sixgunkelly
4Speed...Where did you get that castrol cleaner ,auto parts store???Thats the kinda stuff that was hope'n would be out there to use,Thanks,Sixgun
Old 02-02-2005, 09:09 PM
mr4speedford
Walmart! It came in a gallon bottle and the bottle was purple. I used it soak my head bolts in after they were removed. After about 24hr soaking, I pulled the bolts out, and dried them with a paper towel and they were as good as new. -4speed
Old 02-03-2005, 10:16 AM
sandrailer99
sandrailer99 is offline
sandrailer99 is starting off with a positive reputation.
muriatic acid used to clean swimming pools will take the rust off down to the steel.works fast just rinse with water.
Old 02-06-2005, 04:50 PM
1yamman350
1yamman350 is offline
1yamman350 is starting off with a positive reputation.
dont hold me respnosible for this if you blow something up cause its extremely flammable, but when i rebuilt my drum brakes, the small parts were filthy. i let them sit in a coffe can full of gas overnight, then took a toothbrush to them. worked pretty good but very dangerouls.
Old 02-06-2005, 06:50 PM
wicky's Avatar
wicky
wicky is offline
DON'T use it on 'soft metels'
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
