2001 ranger pulling to right
Hey guys. Been having a small problem with my ranger for the past couple years but now it seems really bad. When I shift into 4wd the truck wants to pull to the right hard. If I let go of the wheel it will pull me off the road. If I switch back into 2wd it continues this until I steer both ways a few times while moving forward. Any ideas?
Any chance that a) only one front wheel is engaged with the rest of the drivetrain or b) there is damage to/worn parts related to the steering, suspension or frame (accident damage/bent/dogtracking/other)? The answer to this requires an understanding of how to correctly inspect these items so as to not overlook an item that may be contributing to/the cause of the problem.
Again and if me were diagnosing the cause of the problem, I'd want to know that BOTH front tires are capable of pulling the vehicle when 4WD is engaged and that the rest of the items noted in my previous post were carefully investigated. There's a reason this is happening, gotta leave no stone unturned/ignored in the search for it. I assume there are NO mods to the vehicle since none have been noted in a signature in the OP and that everything is therefore, bone stock. No aftermarket wheels noted, correct tire size for the vehicle, etc.
I wonder if there is power available to both front wheels and if the suspension/steering/frame/etc is all tight. This because, it sounds as if something significant happens when 4WD is engaged, be it one tire up front is pulling hard or something in the just noted areas is moving/shifting. Which is why these things have been mentioned twice, along with stressing the importance of correctly inspecting and verifying condition. This because, if it's not done right and if a problem part, etc is *assumed* to be good and ignored, then everything done after that is a waste of time and eventually someone will have to go back and find the oversight.
***Edit: just because it hasn't been wrecked or off roaded hard doesn't automatically mean that everything can be assumed to be ok. Something(s?) is NOT ok, gotta methodically inspect items correctly, and rule them out until the problem is identified.
rutang
18
03-30-2009 07:16 PM
fordguy300
10-20-2008 09:14 AM
dbrutherford
1983 - 2012 Ranger & B-Series
03-03-2005 07:51 PM
