Power door locks still
I am still having trouble with the power door locks. The actuators work, I tested them. When you hit a switch, you hear a clicking below the dash, like a relay. There are relays, but they are on the vehicle security module. My remote unlock doesnt work, but does trip the light when unlocking, and also trips the horn when locking. Anyone have suggestions? I think I need to replace the VSM, but not sure. I would like to find a wiring diagram for this truck, but cant find any manuals.
Im starting to hate this.
Thanks
Jim
Thanks
Jim
Originally Posted by jrisebo
Im sure thats part of the VCM. I am going to get a wiring diagram, and put power to the door locks from the VCM, and see if they work, thus isolating the VCM.
What do you guys think?
None of the actuators are getting power. I cut one of the wires, and hooked to a 12v source, and it worked. I checked the fuse, and its fine. I can hear the relay on the VCM trying to work. When I use my remote keyless entry, it turns on the light, but doesnt unlock.
I am having a simlar issue. On my 01 Excursion I have the following symptoms. Drivers door does not lock or unlock, passenger back door does not lock or unlock either. Passenger front and Drivers back door work most of the time. You can here the relay under the dash and even see the drivers door lock tick just a little when you try to use it. One other thing that seems really strange is that the outsdie keypad can lock the two good doors, but can not unlock any of them....any ideas...I am fresh out.
Al
Al
cleggeggs110..
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Enjoy FTE
