any problems with the 4.6 triton ??? - Page 2 - Ford Truck Enthusiasts Forums
Old 09-24-2008, 04:07 AM
Chrisconsin's Avatar
Chrisconsin
Chrisconsin is offline
Chrisconsin is starting off with a positive reputation.
Originally Posted by indyF-350psd View Post
only problem i had with mine was the pesky egr ports clogging up....
Delete it!
Old 09-26-2008, 10:37 PM
Gevans17
Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
1998 4.6 105,000 miles. only engine repair was a starter after about 8 years
Old 09-26-2008, 10:39 PM
Gevans17
Gevans17 is offline
5w20??
Originally Posted by suzuki0702 View Post
#1 make sure your using the 5w-20 it calls for.. start there. lots of people say thats too thin for an engine. they dont tell you that for jokes and giggles . #2 if thats not the issue use some seafoam in the oil ... maybe a dirty lifter?
Mine calls for 5w30, not 5w20
Old 09-26-2008, 10:47 PM
latoniatank
latoniatank is offline
latoniatank is starting off with a positive reputation.
Question
tried seafoam twice, changed the oil as you specified. still have the propblem, no oil getting to the passenger side head.
Old 10-01-2008, 09:23 AM
97dave
97dave is offline
97dave is starting off with a positive reputation.
I have a 97 4x4 ext cab w/ the 4.6. The truck has about 155000 miles and recently started to purge antifreeze from the cap. Found out it has a bad head gasket and am having a new motor installed. I was a little upset to have this problem with only 155000 miles, but then again the motor is 11 years old. I occasionally pull a 3 horse trailer(4-5k lbs loaded max) and get a couple round bails of hay on an 18ft flat trailer(3k lbs loaded max). The truck does pretty well with both trailers, but a 5.4 would be a little better. Other than the head gasket, the motor has had no hiccups.
Old 10-01-2008, 12:42 PM
Krewat's Avatar
Krewat
Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
97dave, not a dis or anything, more of a technical curiosity, but did you keep the coolant changed every 2 years?
Old 10-03-2008, 01:54 PM
97dave
97dave is offline
sorry for the delay...i took over complete maintenance of this truck @ about 30k miles. I followed the owners manual and had the coolant system serviced accordingly, I do not think it was every 2 years, more like every 3. I cahanged the hoses at 125k and had the coolant flushed and changed then. i replaced the radiator early this year and again flushed the coolant and replaced. I used the type of coolant recommended by ford. Could something having to do with the coolant have caused my problem?
Old 10-03-2008, 04:47 PM
Krewat's Avatar
Krewat
I can't say for sure, but if you needed a radiator, that's an indicator that something was not right. Why did you need a radiator? Did it leak or did it clog up?
Old 10-05-2008, 12:48 PM
alberta46
alberta46 is offline
alberta46 is starting off with a positive reputation.
mine is a 97 5 speed no problems at 285000 km about 175000 miles regular maintenance is all.
Old 11-29-2014, 10:54 PM
mccloskey75
mccloskey75 is offline
mccloskey75 is starting off with a positive reputation.
I just bought one!!
I just bought a 2001 f-150 4.6L v8 triton with 128k miles on it not sure if there's anything that I should change/do sense I first just got the truck also what kind of oil filter to get and any other tips/tricks about the truck
Old 04-26-2016, 09:00 AM
Sukafish89
Sukafish89 is offline
Sukafish89 is starting off with a positive reputation.
Ford expidition Triton v8 4.6 (head)
Ive had 2 spark plugs blow out of the aluminum head so far its a '01 has 171,000 miles how can i prevent future blow outs
Old 04-28-2018, 09:12 PM
Ch1zz's Avatar
Ch1zz
Ch1zz is offline
Ch1zz is starting off with a positive reputation.
Solid
I have a Ď97 f150 with the 4.6 triton v8 and so far itís been solid. Always reliable and seems to be pretty damn tough! New battery and alternator put in last night now she fires up twice as fast! Love it I just wish it was a 5.4
  #28
Old 04-29-2018, 11:27 AM
Bent6
Bent6 is offline
Bent6 is starting off with a positive reputation.
I had a 350,000 mile 1997 4.6. 0 major issues for those miles. Small issues: exhaust studs are too small and tend to fail over time, starter shunt corrodes through requiring a new starter, COP failures, EGR passage plugs up, vacuum elbow on rear of intake cracks/rots, occasional head gasket that leaks coolant, and it's pretty common for them to use oil. For the last 250,000 miles I had it, my 4.6 used about 1qt every 1000 miles, but this caused zero issues.
masonarmstrong
1997 - 2003 F150
02-27-2017 12:10 PM
PACrewCab
Ford Truck Parts for Sale
07-07-2016 05:50 AM
xlt991
1999 to 2016 Super Duty
03-26-2016 07:45 PM
Brad Didit
Modular V8 (4.6L, 5.4L)
03-14-2016 04:22 PM
99problems
New Member Introductions
03-10-2016 04:04 PM
Quick Reply: any problems with the 4.6 triton ???
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
