Mercon SP Tranny Fluid
#61
That article says that the additive package is made by Afton. It doesn't say that the fluid is made by them, and they don't make ATF, they make additives that go into ATF.
When I was working on the TorqShift program from 2001-2004 the MERCON SP that Ford used was made by Shell. Do they still make it? I don't know.
#62
#63
I found it interesting that they compared LV to Mercon V (as in trying to exceed it) versus better than SP...
I'm leaning towards using LV after reading that article...
#64
#65
#66
Mark(s): The write up from Afton that JUGERNAUT so kindly shared with us refers to the quality of base oils (likely Group III), which makes the LV fluid sound very nice. Do either of you know what the SP spec for base oil was/is?
https://www.fcsdchemicalsandlubrican...us187660us.pdf
Also, look up the Shell MSDS following the link I posted earlier. I believe it also says.
I do know that SP has a high content of Group III base oil.
Ford MSDS:
Chemical Name ............................... CAS Number ................... Percent Concentration.............Hazard Classification
PETROLEUM DISTILLATES .................64742-54-7................................60-100%
HYDROTREATED HEAVY
PARAFFINIC
PETROLEUM DISTILLATES,..................64742-52-5................................1-5%
HYDROTREATED HEAVY
NAPHTHENIC
HYDROTREATED HEAVY
PARAFFINIC
HYDROTREATED HEAVY
NAPHTHENIC
Shell MSDS:
Shell ATF SP Fluid
MSDS# 401519E
Version 1.0
Material Safety Data Sheet
Effective Date 01/28/2009
According to OSHA Hazard Communication Standard, 29 CFR
1910.1200
1/8
Print Date 04/30/2011 MSDS_US
1. MATERIAL AND COMPANY IDENTIFICATION
MSDS# 401519E
Version 1.0
1910.1200
1/8
Material Name
: Shell ATF SP Fluid
Uses
: Transmission fluid
#67
#68
Here is the Ford SP MSDS:
Ford MSDS:
Shell MSDS:
Material Name
Ford MSDS:
HYDROTREATED HEAVY
PARAFFINIC
HYDROTREATED HEAVY
NAPHTHENIC
HYDROTREATED HEAVY
PARAFFINIC
HYDROTREATED HEAVY
NAPHTHENIC
Shell MSDS:
Shell ATF SP Fluid
MSDS# 401519E
Version 1.0
1910.1200
1/8
MSDS# 401519E
Version 1.0
1910.1200
1/8
Material Name
Uses
It's good enough if you've heard there's a good amount of Group III in SP, for me anyway...
#69
I think I found the links that led to the conclusions it was a Shell product:
http://www.bobistheoilguy.com/forums...Number=1829776
Automatic Transmission Fluid (ZFLifegaurd6=Ford Mercon SP) [Archive] - Bimmerfest - BMW Forums
Lifeguard6 = Mercon SP? - Page 2 - BMW 3-Series (E90 E92) Forum - E90Post.com
http://www.e90post.com/forums/showthread.php?t=363648
It is all pretty "sketchy" work, but the OP of posts stated he talked directly to Shell in Houston, Tx where they stated that they in fact made the "SP" there (at least in 2010). The guy that was arguing w/ the OP finally states that he contacted "lubeandtune" in and they confirmed that they are the same.
I know ................... a lot of hearsay, but that is all I found!
#70
Group IV is not hydrotreated petroleum oil, so we know it is not that.
#71
#72
See the 4th post down in this link from BITOG (I needed the education also!!!):
CAS #'s and group III's - Bob Is The Oil Guy
After doing the CAS search myself, I see where you were coming from (sorry - I was the one oversimplifying). That CAS number is a large group that can include Group II or Group III.
It seems that if it has the CAS number 64742-54-7 AND says "Synthetic" on the bottle, then it is a Group III. The key is that it is being marked as a Synthetic!
#73
#74
I found the article that I thought stated that SP was comprised of a good amount of synthetic base stock (I save a lot of stuff - finding it takes time - lol). Re-reading it, it implies that, but does not specifically state it (see last paragraph).
LUBE REPORT: Retooled Mercon May Prove Costly
Interestingly enough, it talks about the German ZF formula which supports the claim that it is Shell oil.
#75
The following users liked this post:
