maintinance for 2000 expy
Old Jan 26, 2005 | 08:02 AM
hairman39's Avatar
hairman39
I would like to get info on maintinance on 5.4 liter ,it has 82000 miles and i plan on keeping the truck,but i have no idea what kind of maintinance it needs to maintain it. motor ,transmission ,reaerend, all ive ever done to it is oil change ,and air filter,tire rotation, and a iac valve. when is time for tune up and what does it cosist of? thanks for your help.
Old Jan 26, 2005 | 10:12 AM
buzzard's Avatar
buzzard
Tune up is pretty much plugs only on the Expy.....the stock plugs should last around 100K miles. I'd change the tranny fluid, differential fluids, transfer case fluid, coolant, fuel filter, etc. You're getting fairly close to needing new O2 sensors as well.
Old Jan 26, 2005 | 10:21 AM
hairman39's Avatar
hairman39
tranny fluid vchange
on a transmission should it be flushed or just replace filter and fluid?
Old Jan 26, 2005 | 04:17 PM
npearman's Avatar
npearman
On my 99 which currently has 92k, I did a transmission flush at about 60k. I'll probably do another tranny flush at 120k then at 180k and so on. My dad did this on his 94 suburban and he has 280k on it with the original transmission. Just my 2cents
Old Jan 26, 2005 | 04:19 PM
npearman's Avatar
npearman
Buzzard - when you have a transmission flush done, does it get the differentials and transfer case? or do you have to do those seperately?
Old Jan 26, 2005 | 04:24 PM
npearman's Avatar
npearman
One other thing I forgot. I changed my fuel filter at 87k, I haven't changed my radiator coolant (will do this spring), haven't done my plugs (will do at 100k), haven't done O2 sensors (will probably wait till it runs bad before doing those) but I did clean the IAC valve and throttle body at 85k. I also had to replace the DPFE sensor at 85k due to CEL.
Pistol#1
Oct 12, 2016 06:31 PM
endobear
29
Jul 9, 2012 05:34 PM
Daveyf15096
Jan 29, 2012 07:30 PM
YoungFordAddict66
Nov 11, 2009 09:53 PM
mikenodog
Ford vs The Competition
Oct 10, 2004 11:56 PM
